Use the data in the following table to use the All Addresses tab.
View all IP Addresses
Use this procedure to view primary or secondary IP addresses on all interface types from one EDM tab.
You can create a Secondary IP Interface only on a VLAN interface.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IP.
  3. Select the All Addresses tab.
All Addresses Field Descriptions
Name Description
Interface
Identifies the IP interface.
Type
Displays the address type, either primary or secondary.
Ip Address
Displays the IP address.
Net Mask
Displays the subnet mask for the address.
VlanId
Displays the VLAN ID, if applicable.
VrfId
Displays the associated VRF ID, if applicable.
